Google Nest Doorbell (Battery)
FREE DELIVERY
LIMITED TIME OFFER
BUNDLES
SEE BUNDLE DEALS FOR SOME GREAT GOOGLE SAVINGS!
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Taller field of view with HDR video and night vision
  • See what’s happening at your doorstep from anywhere
  • Alerts for people, packages, vehicles and animals
  • HD Talk and Listen
  • 3 hours of free video history
  • Add more video history with Nest Aware
  • Type: Doorbell
  • Compatible With: Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (3)
SEE BOTH YOUR FRONT DOOR AND NEST CAM FEED, DIRECTLY ON YOUR DISPLAY
= £329.00
Save £88.00
SEE WHO IS AT THE FRONT DOOR DIRECTLY ON YOUR DISPLAY
= £189.00
Save £79.00
USE NEST MINI AS THE CHIME FOR YOUR DOORBELL
= £169.00
Save £59.00
Know more. No wires required.
The Nest Doorbell is the battery-powered video doorbell that works with any home. See what’s happening at your door and answer it from anywhere. A taller field of view lets you see people from head to toe, or boxes on the ground. It has built-in intelligence that can tell the difference between people, packages, animals, and vehicles, and send alerts about what’s important to you. You can even use pre-recorded responses, like "You can just leave it. Thanks!" With 3 hours of free event video history, you can go back and see what you missed. And because there are no wires, you can install it yourself.
Get alerts that matter to you.
The Nest Doorbell lets you see what’s happening at your door and answer it from anywhere. It knows the difference between a person, package, vehicle, and animal, and alerts you when there’s activity, so there’s no guessing.
See who’s there, even when you’re not.
A taller field of view and HDR let you see people clearly from head to toe, and packages on the ground. If you miss something, 3 hours of free event video history lets you go back and see what happened with the Google Home app.
Designed for any door.
The Nest Doorbell is battery powered and wire-free, so it works with almost any door, whether you live in a house or an apartment. And you can install it yourself in just a few simple steps.
Protects your privacy.
The Nest Doorbell uses encrypted video, two-step verification, and enhanced security through your Google Account to help protect your privacy. And a green LED light lets you know when the camera is processing or streaming video.
Check in anytime.
Know what’s happening at your front door 24/7. You can check up on things whenever you want, from anywhere.
See clearly in any light.
See key details in all kinds of light. HDR helps with bright, high-contrast sunlight, and night vision gives you a clear image even in low light and darkness.
See from head to toe.
The Nest Doorbell is designed with a taller vertical field of view that’s great for doorsteps. A 3:4 ratio means it can help you see people from head to toe, and packages left on the ground.
Know if a person is at your door.
The Nest Doorbell can tell the difference between people, packages, animals, and vehicles and alert you when someone’s there.
Choose the areas that matter most.
Activity Zones let you define specific areas and get notified when something happens there. So you only get alerted about things that are important to you.
Know when a package arrives.
With special alerts for deliveries, the Nest Doorbell will let you know when it sees that a package has arrived.
Talk to who’s there, from anywhere.
Talk and listen to visitors through the built-in speaker and microphone. Tell someone you’ll be right there, or let a delivery person know where to leave the package.
Leave visitors a message with just a tap.
Quickly respond to someone at your door by choosing from pre-recorded messages, like "Just a sec, we’ll be right there," or "You can just leave it. Thanks!"
Wi-Fi problems? Not a problem.
If your Wi-Fi goes down or there’s a power outage, the Nest Doorbell will automatically record important events for up to one hour in its local memory. When things are up and running again, you’ll be able to see exactly what happened.
Install it yourself.
The Nest Doorbell is battery powered, which means you can install it yourself. And you can put it at the vantage point that works best for your door.
Connect to your existing doorbell wires and chime.
How you hear your doorbell chime will depend on how you install the Nest Doorbell:
Battery installation
If you choose wire-free installation using battery power, you’ll get an alert on your phone, and on your Google Assistant-enabled speakers or displays when someone rings the doorbell. With wire-free installation, your existing chime will not ring.
Wired installation
You can connect the Nest Doorbell to your existing doorbell wires. If you choose wired installation, you’ll also hear your existing chime when someone rings the doorbell.
Everything works together.
The Nest Doorbell works with other Nest products. Hear announcements on Nest Mini when someone is at the door. And Nest Hub will show you who’s there when someone rings the bell.
Product Description Google Nest - doorbell - Bluetooth, 802.11a/b/g/n - snow
Product Type Doorbell
Integrated Sensors Proximity sensor, motion sensor
Integrated Components Microphone, speaker, camera
Power Source Hardwired, battery
Connectivity Wireless - Bluetooth, 802.11a/b/g/n
Frequency Band 2.4 Ghz, 5 GHz
Camera Max Resolution 1280 x 960 - audio - Day&Night
Camera Zoom 6x digital zoom
Colour Snow
Localisation United Kingdom
Dimensions (WxDxH) 4.6 cm x 2.41 cm x 16 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£179.00
