Google Nest Hub - Chalk
FREE DELIVERY
£79.00
Colours:
49 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Google Nest Hub works with the Nest Hello video doorbell to show you who's at the front door
  • Google Nest Hub works with Nest Cam Indoor to let you check in on any room, so there are no surprises
  • Set the temperature on your Nest Learning Thermostat using your voice
  • Google Nest Hub works with Nest Cam IQ outdoor to show you what your kids or furry friends are up to
  • 2 year warranty
  • Type: Smart Display
  • Compatible With: Google Assistant
  • Stock Status: In Stock
Product codes
Google Nest Hub brings you visual help for any moment at home. With the Google Assistant built-in, use your voice to view your latest events and reminders and to control smart devices from a single dashboard.
Help at a glance.
Google Nest Hub provides help at a glance in any room at home. With the Google Assistant built-in, always see your best and latest shots from Google Photos. Plus, view and control your compatible connected devices from a single dashboard. Simply use your voice to watch YouTube and play songs from YouTube Music. You can even get your calendar, commute, answers from Google, and more.
Relive your memories with Google Photos
Google Nest Hub is the ultimate digital picture frame. With Recent Highlights from Google Photos, see your best and latest pictures automatically–no manual updates required.
Control your connected home
View and control compatible lights, plugs, cameras, TVs and other devices from a single dashboard. Works with Nest devices like thermostats and security cameras along with hundreds of smart devices from popular brands.
Play videos and songs from YouTube
Watch YouTube and play songs and music videos from YouTube Music. Plus, listen to Spotify, Deezer and your favourite radio stations.
Get hands-free help from the Google Assistant
See your personalised schedule, commute, reminders and more with Voice Match. Plus, get visual answers from Google and watch helpful videos from YouTube.
Designed for any room at home.
Google Nest Hub fits naturally in any room at home. With Ambient EQ, Google Nest Hub adjusts to match the colours and lighting in its environment, so photos on Google Nest Hub seamlessly blend in with your home decor. Choose from four beautiful hues available from the Google Store —Chalk, Charcoal, Aqua and Sand—designed to fit in, or stand out if that’s your style.
Tech specs
Dimensions & weight: 178 mm W, 118 mm H
Display: 177.8 mm (7 in) LCD touch screen
Speaker: Full range speaker
Sensors: Light sensor
Connectivity: Wi-Fi and Bluetooth support
Power: 15 W adaptor
Ports: DC power jack
Requirements: Wi-Fi-enabled supported device
Product Description Google Nest Hub - smart display - wireless
Product Type Smart display
Localisation United Kingdom
Speaker Type Active
Amplifier Integrated
Display LCD - 7" touch screen
Interfaces Wi-Fi, Bluetooth
Platform Belkin WeMo, Hue, Nest
Intelligent Assistant Compatible Google Assistant
Streaming Services Deezer, Spotify, TuneIn, Chromecast, YouTube MUSIC
Colour Chalk
Dimensions (WxDxH) 17.8 cm x 6.73 cm x 11.8 cm
Weight 480 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£79.00
