Hey Google, make it easier
Google Nest Hub Max helps your busy family stay in touch and on track. And with the Google Assistant 1, you don’t have to lift a finger. Just use your voice.
Keep everyone connected.
Hey Google, call Mum. Make video calls to friends and family. And leave video messages for each other on Nest Hub Max.2
Stay in touch and in sight.
Multi-task while you make video calls. With auto-framing, the camera keeps you in view as you move around the room.
The ultimate digital picture frame.
See your latest and greatest from Google Photos – automatically.3 They’ll all look beautiful on the 10-inch HD screen.
Check in on home when you’re away.
Keep an eye on things at home with the built-in Nest Cam4. Check in from your phone and get motion and sound alerts. And with a Nest Aware subscription, you’ll also get continuous video recording.
Make your smart home even smarter.
Use your voice to control your Nest thermostat, smart lights, TVs, and hundreds of other compatible smart home devices5. See them all on one screen – no more opening app after app.
Watch what you want, when you want.
With Chromecast built in, stream movies and TV shows from services like Google Play Movies, Netflix, Now TV, Disney+ and more.6
The Google Assistant shows you all you need to know.
Nest Hub Max automatically shows your calendar, commute, reminders and more.7
1 Requires an Internet connection.
2 To make video calls and leave video messages, Google Duo accounts required for you and call recipient
3 To see personal photos, Google Photos is required.
4 Night Vision not supported.
5 Compatible smart devices required.
6 Subscriptions may be required for some content.
7 Personalised features require additional enrolment and setup.
Product Description | Google Nest Hub Max - smart display - wireless | Product Type | Smart display - 2.1-channel | Speaker Type | Active | Amplifier Output Power | 50W | Amplifier | Integrated | Display | LCD - 10" - 1280 x 800 - touch screen | Camera | 6.5 Megapixel | Interfaces | Wi-Fi, Bluetooth | Platform | Belkin WeMo, Hue, Nest | Intelligent Assistant | Google Assistant - direct | Streaming Services | YouTube, Pandora, Spotify, Google Play Movies, Google Maps, Hulu, HBO NOW, Chromecast | Speaker Details | Speaker - stereo x 2 - 10 Watt - active , Speaker - subwoofer - 30 Watt - active | Colour | Charcoal | Dimensions (WxDxH) | 25.01 cm x 10.123 cm x 18.255 cm | Weight | 1.32 kg | Manufacturer Warranty | 2-year warranty |
General | |
Microphone | 2 microphones array |
Sensors | Ambient light sensor |
Enclosure Colour | Charcoal |
Speaker System | |
Audio Amplifier Output Power | 50W |
Interfaces | IEEE 802.11b/g/n/ac, Bluetooth 5.0 |
Internet Streaming Services | YouTube, Pandora, Spotify, Google Play Movies, Google Maps, Hulu, HBO NOW, Chromecast |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Type | Cloud |
Intelligent Assistant Compatible | Google Assistant |
Voice Control | Direct |
Speaker System Details | |
Driver Details | Speaker: 2 x tweeter driver , Speaker: subwoofer driver |
Miscellaneous | |
Included Accessories | AC power adaptor |
Power | |
Power Source | AC power adapter |
Power Consumption Operational | 30 Watt |
Dimensions & Weight | |
Width | 25.01 cm |
Depth | 10.123 cm |
Height | 18.255 cm |
Weight | 1.32 kg |
Manufacturer Warranty | |
Service & Support | 2 year |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
