Google Nest Hub Max - Charcoal
FREE DELIVERY
£199.00
Colours:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Google Nest Hub works with the Nest Hello video doorbell to show you who's at the front door
  • Google Nest Hub works with Nest Cam Indoor to let you check in on any room, so there are no surprises
  • Set the temperature on your Nest Learning Thermostat using your voice
  • Google Nest Hub works with Nest Cam IQ outdoor to show you what your kids or furry friends are up to
  • 2 year warranty
  • Type: Smart Display
  • Compatible With: Google Assistant
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Hey Google, make it easier
Google Nest Hub Max helps your busy family stay in touch and on track. And with the Google Assistant 1, you don’t have to lift a finger. Just use your voice.
Keep everyone connected.
Hey Google, call Mum. Make video calls to friends and family. And leave video messages for each other on Nest Hub Max.2
Stay in touch and in sight.
Multi-task while you make video calls. With auto-framing, the camera keeps you in view as you move around the room.
The ultimate digital picture frame.
See your latest and greatest from Google Photos – automatically.3 They’ll all look beautiful on the 10-inch HD screen.
Check in on home when you’re away.
Keep an eye on things at home with the built-in Nest Cam4. Check in from your phone and get motion and sound alerts. And with a Nest Aware subscription, you’ll also get continuous video recording.
Make your smart home even smarter.
Use your voice to control your Nest thermostat, smart lights, TVs, and hundreds of other compatible smart home devices5. See them all on one screen – no more opening app after app.
Watch what you want, when you want.
With Chromecast built in, stream movies and TV shows from services like Google Play Movies, Netflix, Now TV and more.6
The Google Assistant shows you all you need to know.
Nest Hub Max automatically shows your calendar, commute, reminders and more.7
1 Requires an Internet connection.
2 To make video calls and leave video messages, Google Duo accounts required for you and call recipient
3 To see personal photos, Google Photos is required.
4 Night Vision not supported.
5 Compatible smart devices required.
6 Subscriptions may be required for some content.
7 Personalised features require additional enrolment and setup.
Product Description Google Nest Hub Max - smart display - wireless
Product Type Smart display - 2.1-channel
Speaker Type Active
Amplifier Output Power 50W
Amplifier Integrated
Display LCD - 10" - 1280 x 800 - touch screen
Camera 6.5 Megapixel
Interfaces Wi-Fi, Bluetooth
Platform Belkin WeMo, Hue, Nest
Intelligent Assistant Google Assistant - direct
Streaming Services YouTube, Pandora, Spotify, Google Play Movies, Google Maps, Hulu, HBO NOW, Chromecast
Speaker Details Speaker - stereo x 2 - 10 Watt - active , Speaker - subwoofer - 30 Watt - active
Colour Charcoal
Dimensions (WxDxH) 25.01 cm x 10.123 cm x 18.255 cm
Weight 1.32 kg
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: FCFH 042694
£156.94
product
Ref: FCFH 042694
Accessories
Packaging
Functional
Software
Manuals
£156.94
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Google Nest Hub Max -...
£199.00
