Google Nest Mini (2019) - Charcoal
FREE DELIVERY
£49.00
Colours:
33 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Bigger, richer sound
  • Made with the environment in mind
  • Improved voice recognition
  • Easy volume controls
  • Play music and entertainment from your favourite apps with your voice
  • Get help around your home with your Google Assistant
  • Type: Smart Speaker
  • Compatible With: Google Assistant
  • Stock Status: In Stock
Product codes
Nest Mini.
Better sound. Huge help.
Meet the new Nest Mini. Your music sounds bigger and better than ever. And the Google Assistant is a huge help around the house.
Engineered for sound. Designed for your home.
Bigger, richer sound.
Google Nest Mini has 2x stronger bass than the original Mini.
Made with the environment in mind.
Durable fabric top made from 100% recycled plastic bottles.
Improved voice recognition.
Ask for help from across the room.
Stream your music
Play music and entertainment from your favourite apps with your voice.
Just ask your Google Assistant. Or stream to Nest Mini from your phone.
Get help around your home with your Google Assistant.
Just ask and get the best of Google – weather, news or almost anything. Hear your personalised schedule, commute and reminders. Set timers and alarms.
Control your home with just your voice.
Dim the lights, turn on the TV or turn up the heat – just ask your Google Assistant. Works with hundreds of compatible smart devices.
Product Description Google Nest Mini - Gen 2 - smart speaker
Product Type Smart speaker
Localisation United Kingdom
Speaker Type Active
Interfaces Wi-Fi, Bluetooth
Intelligent Assistant Google Assistant - direct
Streaming Services Chromecast
Colour Charcoal
Sound Effects 360° sound
Dimensions (WxDxH) 4.2 cm
Dimensions - Diameter 9.8 cm
Weight 181 g
Manufacturer Warranty 2 Year Warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Google Nest Mini (2019...
£49.00
