Google Nest Wifi Point
FREE DELIVERY
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Stream with speed
  • Wi-Fi you'll want to show off
  • Being part of your home means respecting your privacy
  • Hands-free help around the house
  • Type: Wi-Fi system
  • Connectivity: Wireless
  • Protocol: Bluetooth 4.2, IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b + 2 more
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Meet the new Nest Wifi.
Strong connection. Every direction.
Nest Wifi blankets your whole home in fast, reliable Wi-Fi and keeps buffering at bay in every room.
Nest Wifi
Nest Wifi is a scalable system that gives both whole-home coverage and a consistently strong signal. Each Nest Wifi point is also a smart speaker with the Google Assistant.
The point
Each point works with the router to expand coverage and help keep Wi-Fi fast in every room.
Plus it’s a smart speaker that you can play music on, find answers, and more.
Which Nest Wifi system is right for you?
Get coverage in every corner, no matter the size and shape of your home.
One router.
Up to 120 square metres
One router and one point.
Up to 210 square metres
One router and two points.
Up to 300 square meters
Set up and manage your Wi-Fi with the Google Home app.
Network controls.
Manage your network right on your smartphone.
Parental peace of mind.
Control online time for the kids and block explicit content.
Prioritise devices.
Pick which devices get faster speeds when you need it.
Share Wi-Fi with your friends.
Create a guest network and easily share your password.
Run a speed test.
You can always see how fast your Wi-Fi is running.
Hands-free help around the house.
The Nest Wifi point has a speaker with the Google Assistant, so you can play music, manage your Wi-Fi network, find answers, control your connected devices and more using your voice.
More points to expand.
Add more points if you need more coverage and help around the house.
Nest Wifi points require a Nest Wifi router or Google Wifi router.
In the box
1 Nest Wifi point
1 power adaptor
Product Description Google Nest Wifi - Add-on - Wi-Fi system - 802.11a/b/g/n/ac, Bluetooth 4.2 - desktop
Device Type Wi-Fi system - mesh
Enclosure Type Desktop
Wi-Fi System Components Extender
Wi-Fi System Coverage Up to 1,600 sq.ft
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Frequency Band 2.4 GHz / 5 GHz
Capacity Connected devices: 100
Intelligent Assistant Google Assistant
Features Roaming function, 2T2R MIMO technology, MU-MIMO technology, beamforming technology, band steering
Compliant Standards IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, Bluetooth 4.2, IEEE 802.11v
Colour Snow
Dimensions (WxDxH) 10.22 cm x 10.22 cm x 8.72 cm
Weight 350 g
Localisation United Kingdom
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: FGH1 042804
£73.42
product
Ref: FGH1 042804
Accessories
Packaging
Functional
Software
Manuals
£73.42
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£129.00
