GoPro 3in1 Mount
FREE DELIVERY
GoPro 3in1 Mount
Key features
  • Can be used three main ways: as a camera grip, extension arm or tripod
  • Configurable for a wide range of uses, from capturing POV footage and selfies, to follow-cam, static tripod shots and more
  • Folding arm makes it easy to capture selfies without the mount appearing in the shot
  • Use the arm plus grip like a pole mount for immersive POV or follow-cam footage
  • Handle can be detached from the arm and used as a camera grip
  • Removable tripod conveniently stores inside the handle
  • Lightweight, mini tripod can be used on its own or combined with the handle
  • Waterproof construction for use in and out of the water
  • Measures 20" (50.8 cm) when fully extended, collapses to 7.5" (19 cm)
Product codes
This ultra versatile mount can be used three main ways: as a camera grip, extension arm or tripod. The folding arm is perfect for POV or follow-cam footage, and makes it easy to capture selfies without the mount appearing in the shot. When detached from the arm, the handle doubles as a camera grip. Stored inside the handle is a lightweight, mini tripod that can be removed and used on its own or combined with the handle. Expands to 50.8 cm, collapses to 19 cm.
  • Use the arm and grip as a handheld boom for immersive POV or follow-cam footage
  • Measures 50.8 cm when fully extended, collapses to 19 cm
What's Included
  • Extension Arm
  • Grip
  • Tripod
  • Thumb Screw
Compatibility
  • All GoPro cameras
GoPro 3-way - support system - shooting grip / mini tripod /shooting grip / mini tripod / selfie stick
Support system - shooting grip / mini tripod /shooting grip / mini tripod / selfie stick
HD HERO; HD HERO2; HERO Session; HERO+ LCD; HERO3; HERO3+; HERO4; HERO4 Session; HERO5; HERO5 Session; HERO6; HERO7 Black, Silver, White
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
GoPro 3in1 Mount
