GoPro El Grande (38in Extension Pole)
FREE DELIVERY
Key features
  • Extends for great perspectives and to get you closer to the action
  • Provides an integrated ball-and-socket design at the end of the pole, allowing you to make adjustments or swivel your camera
  • Premium oversized grip allows you to comfortably use two hands to hold El Grande for a better overall experience
  • Twist-lock design for quick and easy use
  • Durable and waterproof
Product codes
El Grande is an aluminium extension pole that takes your GoPro to new heights – literally. Its extra extension (up to 97 cm) allows you to capture new perspectives and gets you closer to the action. Plus, it’s collapsible down to 38 cm and is compact enough for any on-the-go adventure.
  • Extends to 97 cm for new perspectives and to get you closer to the action. Collapses to 38 cm, so it’s easily packable for on-the-go use
  • Includes an integrated ball-and-socket design at the end of the pole, allowing you to make adjustments or swivel your GoPro 360° without having to stop and unmount your camera
What’s Included
  • Extension Pole
  • Swivel Base with Thumb Screw
  • Wrist Lanyard
Compatibility
  • All GoPro cameras
GoPro EL GRANDE - support system - shooting pole
Support system - shooting pole
Tripod Head Type
Ball and socket
Tripod Operating Height
97 cm
HD HERO; HD HERO2; HERO Session; HERO+; HERO+ LCD; HERO3; HERO3+; HERO4; HERO4 Session; HERO5; HERO5 Session; HERO6 Black; HERO7 Black, Silver, White
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
GoPro El Grande (38in...
