Griffin Airsrtap 360 iPad Air 2, iPad Pro 9.7"
Key features
  • Built-in safety strap makes holding iPad with one hand much more secure
  • Structured frame protects the edges, controls and connectors of your iPad
  • Comfortable contoured edges are easy to grip
  • Wide neoprene strap hugs your hand for additional security when you hold your iPad with one hand
Product codes
A molded frame with thick, comfortable, contoured grips surrounds your iPad, protecting the edges without getting in the way of your controls or ports. Slip your hand under the wide neoprene strap on the back. AirStrap hugs your hand, making your iPad easier to hold whether you're reading in a coffee shop or checking out the headlines as you ride the 6:45 in to work.
Griffin AirStrap 360 - back cover for tablet
Back cover for tablet
Screen Size Compatibility
9.7"
Material
Neoprene, polycarbonate, thermoplastic polyurethane (TPU)
1 year warranty
Apple 9.7-inch iPad Pro; iPad Air 2
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Griffin Airsrtap 360 i...
