Griffin Airstrap 360 iPad Mini 4 Black
ROBUST PROTECTION FOR YOUR IPAD MINI 4!
£21.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Built-in safety strap makes holding iPad with one hand much more secure
  • Structured frame protects the edges, controls and connectors of your iPad
  • Comfortable contoured edges are easy to grip
  • Wide neoprene strap hugs your hand for additional security when you hold your iPad with one hand
  • Stock Status: In Stock
Product codes
A molded frame with thick, comfortable, contoured grips surrounds your iPad, protecting the edges without getting in the way of your controls or ports. Slip your hand under the wide neoprene strap on the back. AirStrap hugs your hand, making your iPad easier to hold whether you're reading in a coffee shop or checking out the headlines as you ride the 6:45 in to work.
Product Description Griffin AirStrap 360 - back cover for tablet
Product Type Back cover for tablet
Designed For Apple iPad mini 4
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Griffin Airstrap 360 i...
£21.98
