Griffin Identity AllClear for iPhone6 Plus/6s Plus - Clear
Key features
  • 4' drop protection with dual-material frame combines shock-absorbing rubber with hard polycarbonate to deflect impacts
  • Raised lip protects front screen and edges from chips and scratches
  • Interchangeable frames and backs let you mix and match looks with any Identity case
Product codes
You shouldn’t have to choose between looking great and keeping your phone safe when you buy a case. And with Identity, you don’t.
Griffin's All Clear Identity cases get both their good looks and their protective abilities from a skillful layering of materials that deflect impacts and vibration while letting the beauty of your iPhone show through.
Identity cases protect your phone from four-foot drops. The dual-material frame is made from color-keyed shock-absorbent rubber bonded to a hard polycarbonate plastic frame. Swap any Identity frame and back plate to create your own unique look, thanks to Identity’s interchangeable design.
Griffin Identity - back cover for mobile phone
Back cover for mobile phone
Material
Polycarbonate, rubber
All clear
Apple iPhone 6 Plus
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Griffin Identity AllCl...
