HGST 1TB Travelstar SATA 6GB/s 5400RPM 8MB 2.5" Laptop H...
HGST 1TB Travelstar SATA 6GB/s 5400RPM 8MB 2.5" Laptop Hard Drive
Key features
  • Advanced format, 512 byte emulation
  • 6Gb/s SATA interface
  • Low power consumption
  • Halogen-free for eco-friendly design
  • Self-encrypting models for data security
  • Enhanced availability (EA) models for applications needing around-the-clock access in lower-transaction environments
Product codes
Travelstar 5K1000 is a 5400 RPM, 500GB/platter, 2.5-inch hard drive. This standard 9.5mm, two-disk design, intended for use in notebook PCs, external storage, gaming consoles and other mobile applications, leverages advanced format, which increases the physical sector size on hard drives from 512 bytes to 4096 (4K) bytes to increase drive capacities and improve error correction capabilities.
Product Description WD Travelstar 5K1000 HTS541010A9E680 - hard drive - 1 TB
Type Hard drive - internal - TrueTrack servo technology, Thermal Flyheight Control (TFC), Advanced Format technology
Capacity 1 TB
Form Factor 2.5" x 1/8H
Data Transfer Rate 600 MBps
Buffer Size 8 MB
Spindle Speed 5400 rpm
Features TrueTrack servo technology, Thermal Flyheight Control (TFC), Advanced Format technology
Dimensions (WxDxH) 70 mm x 100 mm x 9.5 mm
Weight 102 g
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
