HGST 2TB Ultrastar 3.5" SATA-300 7200rpm 32mb
Key features
  • Combining 7200 RPM performance and granular power control
  • Enhanced Rotational Vibration Safeguard (RVS) for robust performance in multi-drive environments
  • 24x7 enterprise-class duty cycle
  • 3Gb/s SATA for configuration flexibility
  • Enhancing data safety and security
Product codes
Doubling the capacity density
As data center professionals across the globe work to meet growing enterprise needs, they face the dilemma of storing more data in the same footprint while also reducing power and HVAC consumption. The new ltrastar A7K2000 provides twice the data storage capacity of the prior generation Ultrastar A7K1000 drive, and does so using fewer watts. It is now possible to achieve a colossal 1.2 petabytes (PB) in the footprint of a standard 19-inch enterprise storage rack by deploying the 2TB A7K2000 in a stack of ten 4U, 60-bay enclosures.
Operating at 7200 RPM, the Hitachi Ultrastar A7K2000 offers better overall performance than slower-RPM, capacity-oriented drives at impressively low power-consumption rates. When compared to the previous generation Ultrastar A7K1000, the A7K2000 offers up to a 155% improvement in sustained data transfer rate, and a 120% improvement in watts-per-GB. With five Advanced Power Management modes, a 36% reduction in watts during low-RPM idle mode, and using less than 1W during standby/sleep mode, the Ultrastar A7K2000 can help data centers achieve lower AC power and HVAC requirements, freeing up precious headroom for growing enterprise needs.
Product Description HGST Ultrastar A7K2000 HUA722020ALA330 - hard drive - 2 TB - SATA 3Gb/s
Type Hard drive - internal - Rotational Vibration Safeguard (RVS)
Capacity 2 TB
Form Factor 3.5" x 1/3H
Interface SATA 3Gb/s
Data Transfer Rate 300 MBps
Buffer Size 32 MB
Spindle Speed 7200 rpm
Features Rotational Vibration Safeguard (RVS)
Dimensions (WxDxH) 10.2 cm x 14.7 cm x 2.6 cm
Weight 0.74 kg
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
HGST 2TB Ultrastar 3.5...
