Hive Hub - Wireless Smart Home Hub Unit
FREE DELIVERY
Product codes
Hive hub
The Hive Hub is the heart of your connected home. It connects your Hive products so you can control them remotely with the Hive app from wherever you are – on your smartphone, tablet or laptop. Just plug it into your broadband router, pair your Hive products and you’re good to go.
  • Set up in seconds
  • Link your Hive products
  • Plugs directly into your router
Product Description Hive Hub - central controller
Product Type Central controller
Dimensions (WxDxH) 9.61 cm x 2.73 cm x 9.66 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Hub - Wireless Sm...
