Hive hub
The Hive Hub is the heart of your connected home. It connects your Hive products so you can control them remotely with the Hive app from wherever you are – on your smartphone, tablet or laptop. Just plug it into your broadband router, pair your Hive products and you’re good to go.
Product Description | Hive Hub - central controller | Product Type | Central controller | Dimensions (WxDxH) | 9.61 cm x 2.73 cm x 9.66 cm |
General | |
Dimensions & Weight | |
Width | 9.61 cm |
Depth | 2.73 cm |
Height | 9.66 cm |
Weight | 114 g |
