Hive Hub 360 – Black & Brushed Copper
FREE DELIVERY
£99.00
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Product codes
Hive Hub 360
Connect your Hive devices and look after your home with our most advanced hub yet.
The hub that looks after your home
Hive Hub 360 is our most advanced hub yet; as well as connecting your Hive devices it detects important sounds around your house like your smoke alarm and sends you a notification.
Hear your alarms wherever you are
Featuring 360° audio detection, it senses if a smoke or carbon monoxide alarm goes off, records it and sends you a notification.
Break up break-ins
Your Hive Hub 360 detects and records sounds like glass windows breaking and will send you a notification so you can hear what's happened.
Get your Hive devices working effortlessly together
It's our most advanced hub and connects your Hive devices over a secure, dedicated network so they work brilliantly together.
If your internet goes down, keep your home up and running
Hive Hub 360 has its own internal memory so if your broadband ever goes down your Hive devices and any Hive Actions you’ve set up keep working.
Designed to live anywhere
Hive Hub 360 connects through Wi-Fi so you don't need to plug it into your router. It's also beautifully designed, comes in two colours and will fit seamlessly into your home.
Calm down boy!
You can also set your Hive Hub 360 to pick up dogs barking. Then you can listen in and hear whether they’re in trouble, barking at a stranger or just being noisy.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Hub 360 – Black &...
£99.00
