Hive Light Colour Changing – Bayonet (B22)
£44.00
21 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Save energy, save money
  • Get the lighting just right from wherever you are
  • Set smart schedules
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant, IFTTT
  • Stock Status: In Stock
Product codes
Hive Active Light - Colour Changing - Bayonet fitting
Match your lighting to your moods with our colour-changing smart bulb, in 16 million colours.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and colour to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Get the party started
Jazz up the colour of your home using our colour-changing smart bulb.
Make time in the morning
Turn your lights off from your phone after you've left for work.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
Product Description Hive Active Light - LED light bulb
Light Bulb Type LED light bulb
Socket Type B22
Wattage 9.5 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination RGB/white light
Colour Temperature 2700-6500 K
Luminous Power 806 lumens
Beam Angle 240 degree(s)
Dimmable Yes
Voltage Required AC 220 - 240 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Light Colour Chan...
£44.00
