Hive Light Colour Changing – Screwfit (E27)
FREE DELIVERY
£44.00
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Self install
  • Full RGB & white color changing
  • Durable and high-quality construction materials
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Hive Active Light - Colour Changing - Screw fitting
Match your lighting to your moods with our colour-changing smart bulb, in 16 million colours.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and colour to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Get the party started
Jazz up the colour of your home using our colour-changing smart bulb.
Make time in the morning
Turn your lights off from your phone after you've left for work.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
Product Description Hive Active Light - LED light bulb
Light Source Type LED light bulb
Socket Type E27
Wattage 9.5 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination RGB/white light
Colour Temperature 2700-6500 K
Luminous Power 806 lumens
Beam Angle 240 degree(s)
Dimmable Yes
Intelligent Assistant Google Assistant, Alexa - indirect
Platform Hive
Communications Technology Zigbee
Voltage Required AC 220 - 240 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Light Colour Chan...
£44.00
