Hive Light Cool to Warm - Bayonet (B22)
FREE DELIVERY
£29.00
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Helps save energy
  • Easy to install
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant, IFTTT
  • Stock Status: In Stock
Product codes
Bundle deals (1)
GOOGLE NEST HUB SMART DISPLAY
= £68.00
Save £40.00
Hive Active Light - Cool to Warm White - Bayonet fitting
Match the lighting to your mood. Adjust our Cool to Warm White smart bulb from your smartphone.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and warmth to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Stay focused for longer
Stay energised when you're working late by tuning your Hive Active Light to a cooler shade of white.
Jetting off into the sun?
Schedule your Hive Active Light to come on every evening to give you the peace of mind that it looks like somebody's home.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
Product Description Hive Active Light - LED light bulb
Light Bulb Type LED light bulb
Socket Type B22
Wattage 9 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Warm white light
Colour Temperature 2700 K
Luminous Power 806 lumens
Beam Angle 240 degree(s)
Dimmable Yes
Voltage Required AC 220 - 240 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Light Cool to War...
£29.00
