Hive Light Cool to Warm - Scewfit (E27)
FREE DELIVERY
£29.00
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Full White Color Xchange to create the scenes to suit mood and time of day
  • Tunable white color from warm white 2700K to daylight cool 6500K, so you can match the color tone to your existing standard bulbs
  • Wide 240° beam angle provides full illumination reducing shadowing
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant, IFTTT
  • Stock Status: In Stock
Product codes
Hive Active Light - Cool to Warm White - Screw fitting
Match the lighting to your mood. Adjust our Cool to Warm White smart bulb from your smartphone.
- Just replace your existing light bulb with a Hive Active Light and pair with your Hive Hub.
- Set schedules and pick your brightness and warmth to match the moment.
- Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Stay focused for longer
Stay energised when you're working late by tuning your Hive Active Light to a cooler shade of white.
Jetting off into the sun?
Schedule your Hive Active Light to come on every evening to give you the peace of mind that it looks like somebody's home.
Come home to a brighter welcome
Flick your lights on from outside when you reach the front door.
Product Description Hive Active Light - LED light bulb
Light Bulb Type LED light bulb
Socket Type E27
Wattage 9 W
Colour of Illumination Cool daylight/warm white light
Colour Temperature 2700-6500 K
Beam Angle 240 degree(s)
Dimmable Yes
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Light Cool to War...
£29.00
