Hive Light Dimmable - Screwfit (E27)
FREE DELIVERY
£19.99
Delivery:
Key features
  • Save energy, save money
  • Get the lighting just right from wherever you are
  • Lighting how you like it
  • Turn them off together
Product codes
Hive Light Dimmable - Screw fitting
Down for Sunday night, up for Monday morning: set our dimmable smart bulb to the level you want with a tap of the Hive app.
  • Just replace your existing light bulb with a Hive Light and pair with your Hive Hub.
  • Set schedules and pick your brightness to match the moment.
  • Save energy by controlling your lights remotely. A great way to reduce your energy bills.
Make time in the morning
Turn your lights off from your phone after you’ve left for work.
Keep the bogeyman at bay
Little ones afraid of the dark? Connect your Hive Light to a Hive Sensor with Hive actions, so as soon as they’re up, the landing light is too.
Movie nights done right
Lower the lights without leaving your sofa using your Hive app.
Product Description Hive Active Light - LED light bulb
Light Bulb Type LED light bulb
Socket Type E27
Wattage 9 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Warm white light
Colour Temperature 2700 K
Luminous Power 806 lumens
Beam Angle 240 degree(s)
Dimmable Yes
Voltage Required AC 220 - 240 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Light Dimmable -...
£19.99
