Hive Light Dimmable Smart GU10 Bulbs - 10 Pack
FREE DELIVERY
£129.00
Delivery:
Standard: 1-3 working days
Key features
  • Match the lighting to your mood
  • Make it look like you're in when you're out
  • Save energy, save money
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant, IFTTT
  • Stock Status: In Stock
Product codes
Hive Dimmable Spotlights - 10 Pack
Hive smart GU10 spotlights are a great way of making your home cosy when you're there and looking lived in when you're not. Use the Hive app to get the lighting just how you like it, just when you need it, from anywhere.
Get the light just right
If you like your lights up in the kitchen to see what's cooking - and down in the living room for movie night - this is the smart bulb for you.
Control from your smartphone
Adjust these smart spotlights with a tap of the Hive app.
Turn them off together
As well as controlling single bulbs, you can also group sets of our Hive smart bulbs so that they work as one. Perfect for your kitchen spotlights.
Set them up in minutes
Just replace your existing spotlights with ours and pair with your Hive Hub.
Make it look like you’re in when you’re out
Hive Lights are brilliant for giving you a little extra peace of mind while you're away. Make it seem like someone’s home by setting lighting schedules. Or with Mimic mode, included as part of Hive Live membership, get your lights to turn on and off in a varied pattern.
Our long-lasting LED smart spotlights are a bright way of saving for the long-term. They're rated A+ for energy efficiency and by controlling them remotely you can make sure they're not left on.
Control them with your voice
All Hive Lights work with both Amazon Alexa and Google Home so anyone can use their voice to turn all the lights on or off together. Perfect for when your hands are full and you can’t get to the Hive app.
Light bulb moments
Did you know you can connect your Hive Lights with other Hive devices in the app so your home works around you? For example, if you have a Hive Sensor your lights can turn on when you walk in the door or off when you leave.
Product Description Hive Light - LED light bulb with reflector
Light Bulb Type LED light bulb with reflector
Packaged Quantity 10 (specifications are for single item)
Socket Type GU10
Wattage 4.8 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Warm white light
Colour Temperature 2700 K
Luminous Power 350 lumens
Number of LEDs 4
Dimmable Yes
Voltage Required AC 220 - 240 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Light Dimmable Sm...
£129.00
