Hive Motion Sensor
FREE DELIVERY
Hive Motion Sensor
£34.82
Delivery:
  • Type: Motion sensor
  • Compatible With: Alexa, Google Assistant, IFTTT
Product codes
Bundle deals (2)
GOOGLE NEST HUB SMART DISPLAY
= £73.82
Save £50.00
NEST MINI SMART SPEAKER
= £63.82
Save £20.00
Hive Motion Sensor
Relax. Our Hive Motion Sensor lets you know everything’s okay back home so you can take it easy wherever you are.
  • Get notifications when motion is detected when you're away
  • Attach and set up in seconds
  • Use with Hive Actions to control heating, lighting and plugs
Kids home early from school?
The Hive Motion Sensor will notify you so you can check they’re home and starting their homework on time.
See in the dark
With Hive Actions, set your Hive Motion Sensor to trigger your Hive Active Light and find your way to the bathroom without bumping into the wall.
Body on the beach, mind on the book
Get stuck into that novel knowing that nothings moving about at home with your Hive Motion Sensor.
Product Description Hive - motion sensor
Product Type Motion sensor
Power Source Battery
Connectivity Wireless
Dimensions (WxDxH) 2.4 cm x 2.5 cm x 8.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Hive Motion Sensor
£34.82
