Hive Multizone
FREE DELIVERY
Hive Multizone
£99.00
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Change your heating and hot water (if you have a hot water tank) settings from your phone, wherever you are
  • You'll never need to heat an empty home again, so you could save up to £150 a year on your heating bills
  • Only a Hive thermostat is installed by a trusted British Gas engineer, no matter who supplies your energy
  • Type: Thermostat
  • Compatible With: Alexa, Google Assistant, IFTTT
  • Stock Status: In Stock
Product codes
Bundle deals (1)
KIT OUT YOUR HOME WITH THIS ULTIMATE HIVE BUNDLE
= £291.97
Save £25.00
Hive Multizone
Stay comfy and save money by creating different temperature zones in your house.
  • Save energy by only heating parts of your home you’re using
  • Set different rooms to different temperatures
  • Control all your Hive thermostats from one place
Sahara, Seville, South Pole
Set up to three different temperature zones, so everywhere is just how you like it.
Set up and start saving
Only heat the parts of your home that you’re using at any time.
Multiple thermostats. One app.
Operate all your temperature zones from one place.
Product Description Hive Active Heating - thermostat
Product Type Thermostat
Functions Control heating systems, location tracking, water control
Power Source Battery
Connectivity Wireless
Dimensions (WxDxH) 10 cm x 4.8 cm x 10 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Multizone
£99.00
