Hive Smart Lights Pack Bayonet (Hub and 2x Bulbs)
FREE DELIVERY
LIMITED TIME OFFER
PRICE DROP
BLACK FRIDAY DEAL! USUALLY £79!
£54.00
Delivery:
Key features
  • Save energy, save money
  • Get the lighting just right from wherever you are
  • Lighting how you like it
  • Turn them off together
  • Includes two bulbs and Hive hub
  • Type: Light bulb
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle contains 2 x Hive Active Light Dimmable Bulbs (Bayonet Fitting) and a Hive Hub
Hive Active Light Dimmable bulbs (HALIGHTDIMWWB22)
Control your lights remotely from the Hive app and set schedules to make it look like you’re home when you’re out, or to set the perfect mood as you settle down for movie night.
Manage your lighting via the Hive app on your phone, so it’s just how you like it, just when you need it.
Make it look like you’re in when you’re out
Hive Lights are brilliant for giving you a little extra peace of mind while you're away. Make it seem like someone’s home by setting lighting schedules. Or with Mimic mode, get your lights to turn on and off in a varied pattern.
Set them up in seconds
Just replace your existing light bulbs with Hive Light bulbs and pair them with your Hive Hub. So you can spend more time doing the things you love.
Set up Hive Actions
Hive Lights can also connect to other Hive devices like sensors (sold separately) through your Hive app. So your lights can turn on automatically when you walk through the front door.
Our long-lasting smart bulbs are rated A+ for energy efficiency, and by controlling them remotely you can make sure they're not left on.
Manage them with your voice
All Hive Lights work with both Amazon Alexa and Google Assistant so anyone can use their voice to turn all the lights on or off together. Perfect for when your hands are full and you can’t get to the Hive app.
Hive Hub (HAH2HUBRETAIL)
The heart of your connected home.
Manage your Hive home
Connect all of your Hive products and manage them remotely with the award-winning Hive app on your smartphone, tablet or laptop.
Get your devices working together
Set up a Hive Action so your home works around you. Like getting a sensor to turn on your camera the moment you step out of the front door.
Easy to install and get started
Just plug it into your broadband router, pair your Hive products and you’re ready to start adding your Hive bulbs.
Product Contains 2 x Hive Active Light LED light bulbs; 1 x Hive Hub
Light Bulb Type LED light bulb
Socket Type B22
Wattage 9 W
Light Bulb Energy Efficiency Class A+
Colour of Illumination Warm white light
Colour Temperature 2700 K
Beam Angle 240 degree(s)
Dimmable Yes
Lifetime 25000 hours
Features Android compatible, iOS compatible
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Smart Lights Pack...
£54.00
