Hive Window or Door Sensor
FREE DELIVERY
£29.00
Delivery:
  • Type: Door and window sensor
  • Compatible With: Alexa, Google Assistant, IFTTT
Product codes
Enjoy life to the full, knowing that everything’s safe at home with our Hive Window or Door Sensor.
  • Get notifications if a door or window is opened when you’re away
  • Attach and set up in seconds
  • Use with Hive Actions to save on heating and lighting
Enjoy your night out
Check you shut the bedroom window properly on the Hive app.
Know when your kids are home
Our Window or Door Sensor will send you a notification when the front door is opened or closed.
Product Description Hive Window or Door Sensor - door and window sensor
Product Type Door and window sensor
Power Source Battery
Connectivity Wireless
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Hive Window or Door Se...
£29.00
