Honeywell C2 Full HD WiFi Indoor Security Camera
FREE DELIVERY
£109.99
Delivery:
  • Type: Indoor Camera
  • Compatible With: Alexa, IFTTT
Product codes
Honeywell C2 Wi-Fi Security Camera
The security camera that recognizes your baby crying
Honeywell's indoor C2 Wi-Fi Security Camera can recognize the difference between a crying baby and a smoke alarm, and sends a notification to your smart device if it hears either. It also lets you watch what's happening at home, anytime, anywhere, and can detect other unusual movements and sounds. Versatile and easy to install, you can combine multiple cameras through the same app to keep an eye on your whole home yourself. Now you can see more and hear more.
Intelligent sound detection
The C2 recognizes many sounds and knows the difference between them. Mount it in your baby nursery and it can alert you to your baby crying and sends a notification if compatible smoke or carbon monoxide alarms are triggered, letting you act quickly.
Night Vision
Advanced night vision mode and incredible clarity helps you keep an eye on things when the sun goes down, for more reliability and quality, and added peace of mind around the clock.
Geofencing
The Honeywell Home app uses geofencing to track your location, enabling home and away modes. It automatically turns the camera on when you leave the house, then off when you come home. So it’s always in tune with your movements.
High Definition Wide-angle View
The powerful 145° wide-angle view lets you see more in pin-sharp 1080p high definition, with wall, table and ceiling mounted options to suit your home.
Adjustable Alert Zones
Set up to four special alert zones to monitor windows or doors, while ignoring background motion like ceiling fans, so you can see more of the things you care about, and less of what you don’t.
Two-way audio
Handy two-way audio means you can keep in touch instantly, wherever you are. So if you see your playful dog eating the mail, you can tell him to stop - right there and then.
Cloud and SD Storage
For total security, enjoy free secure cloud storage to stream and download surveillance clips from the past 24 hours. The encrypted 8GB SD card acts as back-up if Wi-Fi is unavailable.
How it works
Easy-to-install and self-monitored, the Honeywell C2 Wi-Fi Security Camera is quick to set up, even for those that don’t do DIY.
Step 1 - Get the Honeywell Home app - Available for Apple or Android, the Honeywell Home app allows you to use your smartphone or tablet to monitor and control your Honeywell C2 Wi-Fi Security Camera anytime, anywhere.
Step 2 - Simple to set up - The Honeywell Home app will guide you through set-up step-by-step. The table-top or wall-mounted options means there's no complicated wiring — just plug it in, connect the Honeywell Home app and you're ready.
Step 3 - Control from anywhere - The Honeywell Home app knows to turn your camera on or off based on your location — so wherever you are, you can take comfort, knowing you can still keep an eye on the most precious things in life.
Honeywell Home App
Stay in control of your home comforts, even when you're away.
One app for your connected home:
We’re saying "goodbye" to the Honeywell Lyric app and "hello" to the Honeywell Home app, to make room for big improvements.The Honeywell Home app has more features, like the usability upgrades you’ve asked for, one-touch dashboard and improved geofence. It provides a better experience for you by bringing our T6 thermostats, security and awareness products together under one roof – onto a single app on your mobile device.
With the Honeywell Home app, you can take control of your home comforts and always know what's going on at home, at the touch of a button. Available for Android and iOS devices, it puts you in charge of your smart home devices, wherever you are.
One Touch Dashboard - Conveniently verify the status and control your connected devices from one place. Change your temperature setting, view the status and last image taken by your camera, or watch the relative humidity of your water leak detector.
Simple Setup - Getting started is quick and easy as the app guides you through each simple step. It’s equally easy to use, with pre-configured scheduling and a wide choice of settings.
Family Access - Conveniently verify the status and control your connected devices from one place. Change your temperature setting, view the status and last image taken by your camera, or watch the relative humidity of your water leak detector.
Location Based Control (Geofencing) - Our geofencing technology just got smarter: More accurate location awareness means more precise performance. Using geofencing technology, the Honeywell Home app keeps track of your location and knows when you’re returning - adapting your smart home technology to suit your needs. Your thermostat will automatically set to your preferred temperature, ensuring your home is comfy and cosy on your arrival. Home or away modes will also be enabled on your C1 and C2 Security Cameras depending on your location, automatically turning the camera on when you leave the house, then off when you come home. So it’s always in tune with your movements.
Programmable - The Honeywell Home app is as flexible as you are. So you can program your comforts for the week ahead — and adjust them easily if your plans change suddenly.
Always know what's going on at home - Our indoor security camera lets you watch what’s happening at home, so if something happens when you’re not there, you can take action.
Powerful Camera:
• 1080p Full HD
• 145° Wide-Angle View
• 6x Zoom
• Four Adjustable Alert Zones
• Motion & Sound Detection
• Two-Way Audio
• Night Vision
• Flexible mounting on wall or table top
• Plug-in power
• Not professionally monitored
Versatile App:
• 24/7 Live Video
• Smart Mobile Alerts
• 256-Bit Encryption
• Adapts to Your Location or Use Home & Away Modes
Product Description Honeywell C2 - Full HD WiFi Indoor Security Camera
Device Type Indoor Security Camera
Audio Yes: two-way audio capability
Dimensions (WxDxH) 11.4 cm
Weight 142 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Video Modes 1080p
Interfaces WiFi
Features Motion sensor, sound sensor
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Honeywell C2 Full HD W...
£109.99
