Honeywell EVO Wireless Internal Battery Siren
FREE DELIVERY
£57.14
Delivery:
Key features
  • Receive alerts on your smartphone when the detector is triggered
  • Easy to install
Product codes
Wireless Battery Internal Siren
If an intruder triggers your system, a loud 120 decibel siren will sound in your home to act as a deterrent.
  • Sound level 120dBA
  • Three batteries CR123A supplied
  • 4 year battery life
  • 165 x 70mm
  • This product only works with Wireless Evohome Security Hub. Search 'HS9HUBGPRS'.
Honeywell App
Total Connect Comfort - Control your home comforts from your smartphone. Anytime, anywhere.
Smarter homes are connected homes - better control, more comfort and bigger energy savings. Use your mobile to monitor and control your heating, any time, anywhere.
Total Connect Comfort features:
- Total Connect Comfort brings you the peace of mind you need, knowing your home is safe, secure and under your control.
- Control your heating from anywhere using mobile devices.
- Manage multiple thermostats and locations.
- View and change temperature settings and heating schedules.
- Activate quick actions and system modes.
- See the current outdoor temperature and 5-day forecast.
- Get connection alerts.
- Automatic software updates.
Honeywell & IFTTT
Evohome and the Single Zone Thermostat work in harmony with IFTTT, allowing you to automate your home’s heating around you and your life, in real time.
With IFTTT, you can link and manage your system by creating simple Applets, which could be set to automatically turn your heating off when you’re out of the home, or to switch back on if it snows. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities, to adjust your home comforts to suit you.
Honeywell Evohome SI800MS - siren
Siren
Power Source
Wireless
Frequency Band
868 MHz
White
16.5 cm x 16.5 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Honeywell EVO Wireless...
£57.14
