Honeywell EVO Wireless Motion Sensor & Camera
FREE DELIVERY
£59.98
Delivery:
Key features
  • Wireless video verification allows you to see what is happening at home if an alarm is activated
  • Pet Immunity
  • Walk-Test Mode
  • Built-in temperature alarm sensor
  • Type: Motion sensor / camera
  • Compatible With: IFTTT
Product codes
Wireless Motion Sensor with Camera
If the battery-powered sensor detects an intruder it takes a snapshot, keeping you informed through your smartphone. It can even take pictures in the dark.
  • 11 x 12m range
  • Pet-immune, up to 36kg
  • Colour, with black and white images in darkness
  • 640 x 352 resolution
  • Two batteries (CR123A) supplied
  • 4 year battery life
  • 55 x 121 x 64mm
  • This product only works with Wireless Evohome Security Hub. Search 'HS9HUBGPRS'.
Honeywell App
Total Connect Comfort - Control your home comforts from your smartphone. Anytime, anywhere.
Smarter homes are connected homes - better control, more comfort and bigger energy savings. Use your mobile to monitor and control your heating, any time, anywhere.
Total Connect Comfort features:
- Total Connect Comfort brings you the peace of mind you need, knowing your home is safe, secure and under your control.
- Control your heating from anywhere using mobile devices.
- Manage multiple thermostats and locations.
- View and change temperature settings and heating schedules.
- Activate quick actions and system modes.
- See the current outdoor temperature and 5-day forecast.
- Get connection alerts.
- Automatic software updates.
Honeywell & IFTTT
Evohome and the Single Zone Thermostat work in harmony with IFTTT, allowing you to automate your home’s heating around you and your life, in real time.
With IFTTT, you can link and manage your system by creating simple Applets, which could be set to automatically turn your heating off when you’re out of the home, or to switch back on if it snows. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities, to adjust your home comforts to suit you.
Product Description Honeywell CAMIR-8EZS - motion sensor / camera
Product Type Motion sensor / camera
Environment Indoor
Power Source Battery
Connectivity Wireless
Frequency Band 868 MHz
Camera Max Resolution 640 x 320 Day&Night
Colour White
Dimensions (WxDxH) 6.4 cm x 5.5 cm x 12.1 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Honeywell EVO Wireless...
£59.98
