Honeywell EVO Wireless Pet-Immune Motion Sensor
Key features
  • Receive alerts on your smartphone when the detector is triggered
  • Easy to install
Product codes
Add one of these sensors to each room and they'll trigger an alarm when movement is detected, thanks to a high quality lens, heat detection and passive infrared. It’s especially useful for pet owners – you can detect (and ignore) animals weighing up to 36kg.
  • 10 x 12m range
  • Pet-immune, up to 36kg
  • One battery (CR123A) supplied
  • 4 year battery life
  • 112 x 60 x 40mm
  • This product only works with Wireless Evohome Security Hub. Search 'HS9HUBGPRS'.
Honeywell App
Total Connect Comfort - Control your home comforts from your smartphone. Anytime, anywhere.
Smarter homes are connected homes - better control, more comfort and bigger energy savings. Use your mobile to monitor and control your heating, any time, anywhere.
Total Connect Comfort features:
- Total Connect Comfort brings you the peace of mind you need, knowing your home is safe, secure and under your control.
- Control your heating from anywhere using mobile devices.
- Manage multiple thermostats and locations.
- View and change temperature settings and heating schedules.
- Activate quick actions and system modes.
- See the current outdoor temperature and 5-day forecast.
- Get connection alerts.
- Automatic software updates.
Honeywell & IFTTT
Evohome and the Single Zone Thermostat work in harmony with IFTTT, allowing you to automate your home’s heating around you and your life, in real time.
With IFTTT, you can link and manage your system by creating simple Applets, which could be set to automatically turn your heating off when you’re out of the home, or to switch back on if it snows. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities, to adjust your home comforts to suit you.
Product Description Honeywell Evohome IRPI8EZS - motion sensor
Product Type Motion sensor
Power Source Battery
Connectivity Wireless
Frequency Band 868 MHz
Colour White
Dimensions (WxDxH) 6 cm x 4 cm x 11.2 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Honeywell EVO Wireless...
