Honeywell EVO Wireless Remote Control Key Fob
FREE DELIVERY
£21.78
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
  • Type: Remote control
  • Compatible With: IFTTT
  • Stock Status: In Stock
Product codes
Arm or disarm your system from up to 150 metres, with just one push of a button. Disarm the system from your car – or partially arm it from your bed. There’s a panic button in case of an emergency. LED indicators show the system status, making it even easier to use.
  • Arm, partially arm and disarm the system
  • LED indications for user feedback (low battery, system status – arm, disarm, partial arm)
  • Panic function
  • One battery (CR2032) supplied
  • 4 year battery life
  • 56 x 48 x 9mm
  • This product only works with Wireless Evohome Security Hub. Search 'HS9HUBGPRS'.
Honeywell App
Total Connect Comfort - Control your home comforts from your smartphone. Anytime, anywhere.
Smarter homes are connected homes - better control, more comfort and bigger energy savings. Use your mobile to monitor and control your heating, any time, anywhere.
Total Connect Comfort features:
- Total Connect Comfort brings you the peace of mind you need, knowing your home is safe, secure and under your control.
- Control your heating from anywhere using mobile devices.
- Manage multiple thermostats and locations.
- View and change temperature settings and heating schedules.
- Activate quick actions and system modes.
- See the current outdoor temperature and 5-day forecast.
- Get connection alerts.
- Automatic software updates.
Honeywell & IFTTT
Evohome and the Single Zone Thermostat work in harmony with IFTTT, allowing you to automate your home’s heating around you and your life, in real time.
With IFTTT, you can link and manage your system by creating simple Applets, which could be set to automatically turn your heating off when you’re out of the home, or to switch back on if it snows. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities, to adjust your home comforts to suit you.
Product Description Honeywell remote control
Device Type Remote control
Enclosure Colour Black
Dimensions (WxDxH) 4.8 cm x 0.9 cm x 5.6 cm
Weight 19 g
Connectivity Technology Radio
Battery CR2032
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Honeywell EVO Wireless...
£21.78
