Honeywell Lyric T6R-HW Smart Thermostat with Hot Water Control
Key features
  • Connects to the Internet so you can control your heating system from anywhere with the Lyric App
  • Remotely view and change your heating system settings
  • Diverse programming options that fit any lifestyle
  • Group scheduling for multiple devices and locations (set-up and manage via the Lyric App)
  • Receive alerts (such as boiler failure) from the Thermostat, App, and email
Product codes
Documents
Introducing the T6 Smart Thermostat
People have taken comfort in our expertise for over 100 years, during which we’ve made air travel safer and helped put a man on the moon. Now you can take comfort in an innovative thermostat that adapts to your schedule, helps save you energy and makes your home smarter. To create it, we’ve worked with some of our best engineers. So you can take control of your home comforts, wherever you may be.
Location Based Temperature Control (Geofencing)
Control via smartphone or tablet, anywhere. The Honeywell Home app takes care of everything at home using your smartphone location to determine when you’re home or away. Saving energy when you're away, ensuring the temperature is just right when you return.
Programmable, Adjustable, Adaptable
We know life is unpredictable. That’s why you can choose either 7-Day Scheduling or change things remotely if your plans change.
Connect Your Home
The T6 Smart Thermostat works with Apple HomeKit, Amazon Echo, Google Home and IFTTT to take care of your home comforts and keep your home connected, now and in the future.
Take Control with the Honeywell Home app
At the beach. In the air. At your desk. Take comfort knowing you can control your T6 Smart Thermostat simply and easily - anywhere, any time.
- To get you started quickly, the Honeywell Home app will guide you through the simple set up, step-by-step.
- Compatible with Android and iOS, the app puts you in charge of your T6 Smart Thermostat, so you're always in control of your home comforts.
- Link multiple smartphones and tablets to your thermostat for all the family.
Smart features
Honeywell Home knows how long it takes to get your home to the right temperature, removing the guesswork and saving you money on your energy bills. Ask for 21 degrees at 7am, no problem, the T6 works out how to get there, whatever the outside temperature. Its intelligent comfort control helps maintain the desired temperature when you need it. So your home will always be comfy and cosy, whatever the weather.
Make Coming Home Comfortable
The T6 adapts to your lifestyle using innovative geofencing technology. It knows when you’re away, helping to save energy. It also knows when you’re just around the corner — and ensures your home is at the perfect temperature when you arrive. Giving you total peace of mind and maximum home comfort.
Connecting with other smart brands
Your T6 Smart Thermostat works with many of today’s smart home brands and we're connecting to more devices every day. Working in harmony with Apple HomeKit, Amazon Echo, Google Home and IFTTT, you can manage your home comforts smartly and efficiently.
Apple Homekit
The T6 Smart Thermostat works with Apple HomeKit, so you can efficiently manage your smart home using Apple's voice assistant, Siri. You can take comfort knowing you can control your home comforts, now and in the future.
Apple Watch
Control your T6 thermostat from your Apple Watch, with the Honeywell Home App, wherever you are. Interact with your thermostat quickly and easily from home or away, and control the temperature in your home, at any time.
Amazon Alexa
Take your home comfort to the next level with Amazon Echo. The T6 Smart Thermostat works in perfect harmony with its cloud-based voice service, Alexa, so you can easily set the temperature, or turn the heat up or down using voice commands.
Google Home
Your T6 Smart Thermostat connects seamlessly to Google Home and its voice activated Google Assistant, so you can set the perfect temperature using simple voice commands. Just start with ‘Ok Google.’
IFTTT
With IFTTT, you can automatically link and manage your T6 Smart Thermostat by creating simple Applets. These can be turned on and off, and link multiple smart devices, giving you flexibility and infinite possibilities.
Hot Water Control
The T6R model is mobile, and with its desk stand design is perfect for use on flat surfaces. Requiring only mains power, it communicates wirelessly to the boiler control unit (included). The T6R-HW additionally includes hot water control.
In the box
Lyric T6R-HR Smart Thermostat with Hot Water Control
2-Channel Receiver Box
Product Description Honeywell Home Lyric T6R-HW - thermostat with Hot Water control
Product Type Thermostat
Power Source Power adapter
Connectivity Wireless - 802.11b/g/n
Frequency Band 868 - 870 MHz
Thermostat LCD
Colour Antracite
Localisation United Kingdom
Dimensions (WxDxH) 10.3 cm x 6.8 cm x 10.8 cm
Resources
The following resources are available for the Honeywell Lyric T6R-HW Smart Thermostat with Hot Water Control
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
