Honeywell Voyager 1200g Barcode Scanner
FREE DELIVERY
£95.91
Delivery:
Standard: 1-3 working days
Key features
  • Outstanding scan performance on poor quality and damaged bar codes
  • Class-leading presentation scanning
  • Multi-interface
  • Superior out-of-box experience
  • Contemporary, ergonomic design
  • CodeGate technology
  • Type: Barcode scanner
  • Form Factor: Handheld
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
Built on the platform of the single-line laser scanner, Honeywell's Voyager 1200g delivers aggressive scan performance on virtually all linear bar codes, including poor quality and damaged codes. Updated object detection, and automatic in-stand detection and configuration enable class-leading presentation scanning that maximizes throughput. Superior scan performance matched with a reliable design combine to provide a versatile linear scanning solution suitable for a wide variety of applications.
The intuitive Voyager 1200g provides fast and reliable scanning of linear bar codes across its full working range, minimizing the need for user training. Whether poorly printed, smudged or faded, the Voyager 1200g decodes difficult-to-read bar codes with ease. The Voyager 1200g also excels at scanning high density bar codes with resolution down to 3.5-mil, eliminating the need to purchase specialty scanners.
A recessed button protected by an integrated rubber co-mold minimizes the impact of accidental drops. Added durability is provided in the form of a protected, scratch-resistant glass window and an IP42-rating. The Voyager 1200g provides outstanding scan performance and reliability for end users seeking an exceptional linear scanning solution.
Product Description Honeywell Voyager 1200g - barcode scanner
Type Barcode scanner - handheld - USB - decoded
Colour Ivory
Minimum Bar Width 3.5 mil
Scan Element Type Linear imager
Scan Speed 100 line / sec
Connectivity Technology Wired
Dimensions (WxDxH) 18 cm x 6.6 cm x 9.7 cm
Weight 125 g
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Honeywell Voyager 1200...
£95.91
