HP - DDR4 - 8 GB - DIMM 288-pin
Key features
  • Dual channel configuration - HP Desktops feature motherboards designed with two memory channels instead of a single channel.
  • Get fast start-up times, meet everyday workloads head on, and run more programs simultaneously with speeds up to 2133 MT/s.
  • Reduce system latencies and significantly improve your system performance with dual channel memory configurations by utilizing the theoretical bandwidth of two memory modules instead of one.
  • Your performance is our business. Each HP Memory model undergoes a rigorous supplier qualification processes for ensured quality and reliability in a variety of networked environments.
Product codes
Maximize your business PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
Product Description HP - DDR4 - 8 GB - DIMM 288-pin - unbuffered
Product Type RAM memory
Capacity 8 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type System specific
Data Integrity Check Non-ECC
Speed 2133 MHz (PC4-17000)
Features Unbuffered
Voltage 1.2 V
OEM Manufacturer Equivalent Part Number HP P1N52AT
Manufacturer Warranty 1 year warranty
Designed For HP 280 G2; EliteDesk 705 G3, 800 G2; ProDesk 400 G3, 490 G3, 600 G2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP - DDR4 - 8 GB - DIM...
