HP - DDR4 - 8 GB - SO-DIMM 260-pin
Key features
  • Ensure that all of your memory characteristics match by upgrading with HP-branded memory that’s been tested for seamless system-level integration with HP PCs.
  • Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements.
  • Protect your investment with the same world-class HP limited warranty you get for your PC.
Product codes
Boost the capabilities of your HP Business Desktop PC and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
HP-tested
Supported by HP
Product Description HP - DDR4 - 8 GB - SO-DIMM 260-pin - unbuffered
Product Type RAM memory
Capacity 8 GB
Memory Type DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type System specific
Data Integrity Check Non-ECC
Speed 2133 MHz (PC4-17000)
Latency Timings CL15
Features Unbuffered
Voltage 1.2 V
OEM Manufacturer Equivalent Part Number HP P1N54AT
Manufacturer Warranty 1-year warranty
Designed For HP 260 G2, t530; Elite Slice, Slice for Meeting Rooms; EliteDesk 705 G3, 800 G2 (mini desktop); EliteOne 800 G2; ProDesk 400 G2 (mini desktop), 400 G2.5, 600 G2 (mini desktop); ProOne 400 G2, 600 G2; Retail System MP9 G2; RP9 G1 Retail System 9015, 9018, 9118
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP - DDR4 - 8 GB - SO-...
