HP EliteBook 1040 G3 - Core i5 6200U / 2.3 GHz - Win 10 Pro
£1,606.21
Delivery:
Key features
  • Collaborate using optional WWAN with Audio by Bang & Olufsen, HP Noise Reduction Software and a 720p webcam.
  • Help reduce costly downtime with advanced security and manageability features from HP.
  • Power through your day with long battery life, 6th Gen Intel® Core™ processors, and up to 16 GB of memory.
  • Work confidently with the thin, elegant and durable HP EliteBook 1040 with a strong all metal diamond cut design, and the HP Premium Keyboard.
Product codes
The sophisticated style of the HP EliteBook 1040 G3 Ultrabook complements the ultimate performance, security, and manageability features that help bring out your finest work.
Carry less, do more
Work confidently with the thin, elegant, and durable HP EliteBook 1040 with the HP Premium Keyboard, and a strong all metal diamond cut design that passed MIL-STD 810G testing.
Productive powerhouse
Power through your day with long battery life, 6th Gen Intel® Core™ processors, up to 16 GB of memory, and PCIe SSDs that yield impressive speed and performance.
Connect and collaborate in style
Collaborate with colleagues from practically anywhere with optional WWAN, a 720p webcam, HP Noise Reduction Software and Audio by Bang & Olufsen.
Security inside and out
HP helps protect you from malware and visual hacking. HP Sure Start with Dynamic Protection protects against BIOS attacks, and the optional HP Sure View integrated privacy screen shields your screen from prying eyes with the touch of a button.
Product Description HP EliteBook 1040 G3 - 14" - Core i5 6200U - 8 GB RAM - 256 GB SSD - UK
Product Type Notebook
Operating System Win 10 Pro 64-bit - English
Processor Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache
Memory 8 GB DDR4 (provided memory is soldered)
Storage 256 GB SSD
Optical Drive No optical drive
Display 14" WLED 1920 x 1080 / Full HD
Graphics Intel HD Graphics 520
Input Device ClickPad
Keyboard UK
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, NFC, Bluetooth 4.2, Gigabit Ethernet
Battery 6-cell - up to 9.75 hours
Dockable Yes
Security Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Dimensions (WxDxH) 33.7 cm x 23.45 cm x 1.58 cm
Weight 1.43 kg
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 1 year
Bundled Services 3 Years HP Care Pack Pick-Up and Return Service for Travellers
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteBook 1040 G3...
£1,606.21
