General |
Type |
Personal computer |
Product Form Factor |
All-in-one |
Built-in Devices |
Fingerprint reader |
Embedded Security |
Trusted Platform Module (TPM 2.0) Security Chip |
Localisation |
Language: English / region: United Kingdom |
Processor / Chipset |
CPU |
Intel Core i5 (7th Gen) 7500 / 3.4 GHz |
Max Turbo Speed |
3.8 GHz |
Number of Cores |
Quad-Core |
CPU Qty |
1 |
Max CPU Qty |
1 |
CPU Upgradability |
Upgradable |
Processor Main Features |
Intel Turbo Boost Technology 2 |
Chipset Type |
Intel Q270 |
Cache Memory |
Installed Size |
6 MB |
Cache Per Processor |
6 MB |
RAM |
Installed Size |
8 GB / 32 GB (max) |
Technology |
DDR4 SDRAM |
Effective Memory Speed |
2400 MHz |
Rated Memory Speed |
2400 MHz |
Form Factor |
SO-DIMM 260-pin |
Slots |
2 (Total) / 1 (empty) |
Features |
Dual channel memory architecture |
Configuration Features |
1 x 8 GB |
Hard Drive |
Type |
SSD - M.2 2280 |
Capacity |
1 x 256 GB |
Interface Type |
PCI Express |
Features |
NVM Express (NVMe) |
Storage Controller |
Type |
1 x SATA |
Optical Storage |
Type |
No optical drive |
Monitor |
Monitor Type |
LED - IPS |
Diagonal Size |
23.8" |
Native Resolution |
1920 x 1080 (Full HD) |
Widescreen Display |
Yes |
Image Aspect Ratio |
16:9 |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Pixel Pitch |
0.2745 mm |
Image Brightness |
250 cd/m² |
Image Contrast Ratio |
1000:1 |
Monitor Features |
72% NTSC colour gamut, Full HD anti-glare |
Graphics Controller |
Graphics Processor |
Intel HD Graphics 630 |
Video Interfaces |
HDMI, DisplayPort |
Audio Output |
Sound Output Mode |
Stereo |
Max Sampling Rate |
192 kHz |
Compliant Standards |
High Definition Audio |
Speakers Included |
2 x right / left channel |
Camera |
Camera |
Yes |
Resolution (MP) |
2 Megapixel (rear), 2 Megapixel (front) |
Resolution |
Full HD |
Features |
IR camera, Windows Hello |
Audio Input |
Type |
Dual array microphone |
Networking |
Ethernet Controller |
Intel I219-LM |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet |
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, IEEE 802.3az |
Expansion / Connectivity |
Bays |
1 (total) / 1 (free) x internal 2.5" |
Slots |
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2280 |
Interfaces |
5 x USB 3.1 Gen 1 (two of them with wake functionality, one of them is charging) , 1 x DisplayPort input , 1 x DisplayPort output , HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x USB 3.1 - Type C |
Miscellaneous |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
Low halogen |
Power |
Device Type |
Power adapter |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Provided |
180 Watt |
Efficiency |
87% |
Power Factor Correction |
Yes (active) |
Operating System / Software |
OS Provided |
Windows 10 Pro 64-bit Edition English |
Software |
HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Velocity, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP BIOSphere Gen3, HP JetAdvantage, HP PhoneWise, HP Management Integration Kit for Microsoft System Center Configuration Manager (free download) |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years |
Dimensions & Weight |
Width |
53.95 cm |
Depth |
19 cm |
Height |
41.92 cm |
Weight |
8.21 kg |
Environmental Parameters |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 90% |
