HP 15.6 Recycled Series Top Load Carrying Case
£75.67
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Carry comfortably by hand with the magnetic, padded handles or over the shoulder with the contoured, shock-absorbing shoulder strap.
  • Marvel at the innovation that converts shredded recycled plastics into small flakes and plastic chips, which are then heated and spun into yarn to create a weather-resistant fabric that looks sharp in and out of the office.
  • Slide your notebook into the padded compartment that keeps it securely in place. Keep your papers separate with the file divider and store your essentials and adapter in the interior pockets or large front stash pocket.
  • Traveling is a breeze
  • Stock Status: In Stock
Product codes
Helps protect the planet and your notebook and daily essentials with the stylish, durable HP Recycled Series 15.6" Top Load, a carryall made from recycled plastics.
Product Description HP Recycled Series Top Load notebook carrying case
Product Type Notebook carrying case
Dimensions (WxDxH) 42.55 cm x 6.35 cm x 38.1 cm
Weight 1.22 kg
Notebook Compatibility 15.6"
Designed For HP 340S G7; Chromebook 11 G8, 11A G8, 14 G6; Chromebook Enterprise 14 G6; Chromebook Enterprise x360; Chromebook x360; Elite c1030; EliteBook 83X G7, 84X G7, 85X G7; EliteBook x360; Pro c640; ProBook 430 G7, 44X G7, 45X G7; ProBook x360; ZBook Create G7, Studio G7; ZBook Firefly 14 G7, 15 G7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP 15.6 Recycled Serie...
£75.67
