HP 150W Smart Power Adapter
Key features
  • Get an adapter that detects and regulates the correct electrical current for your HP Mobile Workstation or HP Docking Station.
  • Plug one end of the adapter into your HP Mobile Workstation or HP Docking Station and the other end into a standard outlet. The included 4.5mm to 7.4mm smart cable allows you to carry one adapter for new and legacy platforms.
  • Power up wherever you work. The compact, reliable adapter fits easily in your notebook’s carrying case and is 50% lighter than its previous generation model.
  • Rest easy with a one-year limited warranty.
Product codes
Conserve battery life, be more productive, and get uninterrupted power for your HP ZBook and select HP Docking Stations with HP 150W Smart AC Adapter.
Product Description HP Smart AC Adapter - power adapter - 150 Watt
Device Type Power adapter - external
Weight 320 g
Localisation English / United Kingdom
Power Capacity 150 Watt
Dimensions (WxDxH) 15.3 cm x 6.6 cm x 2.2 cm
Designed For EliteBook 1050 G1; ZBook 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15 G5 Mobile Workstation, 15u G3 Mobile Workstation, 15v G5 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP 150W Smart Power Ad...
