We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
With added input capacity of 550-sheets and media flexibility, this accessory supports greater productivity and less printer management. Have different print media ready in the printer when you need it, and print up to 900-pages without reloading.
Product Description | HP media tray / feeder - 550 sheets | Product Type | Media tray / feeder | Total Media Capacity | 550 sheets | Number of Media Trays | 1 | Dimensions (WxDxH) | 38.1 cm x 35.7 cm x 13.1 cm | Weight | 3.7 kg | Media Sizes | 215.9 x 355.6 mm, 104.9 x 148.59 mm | Designed For | LaserJet Enterprise M406, MFP M430; LaserJet Managed MFP E42540; LaserJet Pro M304, M402, M404, M409, MFP 4101, MFP M426, MFP M427, MFP M428 |
General | |
Dimensions (WxDxH) | 38.1 cm - 35.7 cm - 13.1 cm |
Weight | 3.7 kg |
Compatibility Information | |
Designed For | HP LaserJet Enterprise M406dn, MFP M430f , HP LaserJet Managed MFP E42540f , HP LaserJet Pro M304a, M402d, M402dn, M402dne, M402dw, M402n, M404dn, M404dw, M404n, M409dn, M409dne, M409dw, M409dwe, M409n, M409ne, MFP 4101dw, MFP 4101dwe, MFP 4101fdn, MFP 4101fdne, MFP 4101fdw, MFP 4101fdwe, MFP M426dw, MFP M426fdn, MFP M426fdw, MFP M426m, MFP M427fdw, MFP M428dw, MFP M428fdn, MFP M428fdw |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
