HP 65W Slim Adapter
HP 65W Slim Adapter
Key features
  • 40% thinner than the standard adapter for easy carrying alongside your notebook in the same carrying case.
  • An integrated USB port conveniently charges other peripherals (sold separately) while you work.
  • Compact and slim design makes HP Smart AC Adapters an ideal travel companion
Product codes
HP 65W Slim Adapter
AC power adapters from HP power your notebook and charge the internal battery simultaneously. These adapters provide you with the ability to power your notebook when away from the office or on the road. X3 Full compatibility depends on platform configuration. If 90W or higher is required note that the notebook will be powered when using basic applications and/or for charging. Performance delays may occur on specific platform configurations if lower than original power supply is used.
HP - power adapter - 65 Watt
Power adapter - external
220 g
Output Voltage
5 / 19.5 V
Power Capacity
65 Watt
12 cm x 5.8 cm x 1.7 cm
Compaq CQ58; Presario CQ57, CQ58; HP 43X; EliteBook 27XX; EliteBook Folio 9470; EliteBook Revolve 810 G1; Envy Pro; Folio 13; Folio 13; Pavilion dv6, dv7; Pavilion Sleekbook 14, 15; ProBook 430 G1, 450 G0, 45X G1, 45XX, 470 G0, 470 G1, 53XX, 64X G1, 65X G1; Spectre XT Pro; SPECTRE XT TouchSmart 15
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP 65W Slim Adapter
