HP 65W Smart AC Adapter
£20.29
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Control the flow while maintaining optimal performance utilizing smart-pin technology, drawing only minimal power when not in use, and helping provide reliable surge protection.
  • Eliminate multiple adapters - a special dongle is provided that allows simple conversion from a 4.5mm connector to the 7.4mm used on some previous HP notebooks.
  • Protect your cable and improve cable manageability. The new right-angled (90°) 4.5mm connector allows access in tight spaces and takes stress off the cord by reducing bending.
  • Stock Status: In Stock
Product codes
Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
Product Description HP Smart AC Adapter - power adapter - 65 Watt
Device Type Power adapter - external
Weight 280 g
Localisation English / United Kingdom
Output Voltage 18.5 V
Power Capacity 65 Watt
Output connectors 1 x power DC jack 4.5 mm
Included Accessories 4.5mm to 7.4mm power DC dongle
Dimensions (WxDxH) 10.6 cm x 4.7 cm x 2.8 cm
Designed For HP 245 G7, 340S G7, 34X G5, 470 G7; EliteBook 735 G5, 735 G6, 745 G5, 745 G6, 755 G5, 830 G6, 840 G6, 840r G4, 850 G6; EliteBook x360; Mobile Thin Client mt45; ProBook 430 G7, 440 G7, 445r G6, 450 G7, 455r G6, 45X G5, 640 G5, 64X G4, 650 G5; ProBook x360; ZBook 14u G5, 14u G6, 15u G6; ZBook x2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£20.29
