HP 65W SMART AC ADAPTOR
Key features
  • Control the flow while maintaining optimal performance utilizing smart-pin technology, drawing only minimal power when not in use, and helping provide reliable surge protection.
  • Eliminate multiple adapters - a special dongle is provided that allows simple conversion from a 4.5mm connector to the 7.4mm used on some previous HP notebooks.
  • Protect your cable and improve cable manageability. The new right-angled (90°) 4.5mm connector allows access in tight spaces and takes stress off the cord by reducing bending.
Product codes
HP 65W Smart AC Adapter
Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
HP Smart - power adapter - 65 Watt
Power adapter - external
280 g
English / United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
18.5 V
Power Capacity
65 Watt
10.6 cm x 4.7 cm x 2.8 cm
1 year warranty
HP 25X G1, 3005, 350 G1; EliteBook 25XX, 27XX, 72X G2, 745 G2, 755 G2, 820 G1, 840 G1, 850 G1; EliteBook Revolve 810 G1, 810 G2; Folio 13; Mobile Thin Client mt40; Officejet 150; Pro x2; ProBook 430 G1, 430 G2, 44XX, 450 G0, 450 G2, 455 G1, 45XX, 470 G0, 470 G1, 470 G2, 64X G1, 65X G1; ZBook 14
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
