HP 711 3-pack 29-ml Cyan Ink Cartridges
£59.16
Delivery:
Standard: 1-3 working days
Key features
  • Fit 29-ml color, 38-ml black cartridges to low print volume or 80-ml black, color 3-packs to high volume.
  • See consistent quality—ultra-pure Original HP inks are designed with your printer for sharp, accurate results.
  • See sharp lines to 0.02 mm (0.0008 inch) minimum line width enabled by Original HP inks and your printer.
  • Type: Print cartridge
  • Technology: Ink-Jet
  • Stock Status: In Stock
Product codes
HP 711 3-pack 29-ml Cyan Ink Cartridge provides sharp, accurate results. See rich colour and sharp line accuracy in fast-drying, smudge-resistant prints. Original HP inks are designed and tested with your printer to provide consistent results.
Product Description HP 711 - 3-pack - dye-based cyan - original - DesignJet - ink cartridge
Product Type Ink cartridge
Printing Technology Ink-jet
HP Sub-brand DesignJet
Printing Colour Dye-based cyan
Capacity 29 ml
Included Qty 3-pack
Compatible with DesignJet T120, T120 ePrinter, T125, T130, T520, T520 ePrinter, T525, T530
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP 711 3-pack 29-ml Cy...
£59.16
