General |
Type |
Personal computer |
Product Form Factor |
All-in-one |
Embedded Security |
Trusted Platform Module (TPM 2.0) Security Chip |
Localisation |
Language: English / region: United Kingdom |
Processor / Chipset |
CPU |
Intel Core i5 (7th Gen) 7500 / 3.4 GHz |
Max Turbo Speed |
3.8 GHz |
Number of Cores |
Quad-Core |
CPU Qty |
1 |
Max CPU Qty |
1 |
CPU Upgradability |
Upgradable |
Processor Main Features |
Hyper-Threading Technology, Intel Turbo Boost Technology 2 |
Chipset Type |
Intel Q270 |
Cache Memory |
Installed Size |
6 MB |
Cache Per Processor |
6 MB |
RAM |
Installed Size |
4 GB / 32 GB (max) |
Technology |
DDR4 SDRAM |
Effective Memory Speed |
2400 MHz |
Form Factor |
SO-DIMM 260-pin |
Slots |
2 (Total) |
Features |
Unbuffered, dual channel memory architecture |
Hard Drive |
Type |
HDD |
Capacity |
1 x 500 GB |
Interface Type |
SATA 6Gb/s |
Spindle Speed |
7200 rpm |
Storage Controller |
Type |
1 x SATA |
Controller Interface Type |
SATA 6Gb/s |
Optical Storage |
Type |
DVD-Writer - SATA |
Monitor |
Monitor Type |
LED - IPS |
Diagonal Size |
23.8" |
Native Resolution |
1920 x 1080 (Full HD) |
Widescreen Display |
Yes |
Image Aspect Ratio |
16:9 |
Horizontal Viewing Angle |
178 |
Vertical Viewing Angle |
178 |
Pixel Pitch |
0.2475 mm |
Response Time |
14 ms |
Image Brightness |
250 cd/m² |
Image Contrast Ratio |
1000:1 |
Monitor Features |
Anti-glare, 72% colour gamut |
Graphics Controller |
Graphics Processor |
Intel HD Graphics 630 Dynamic Video Memory Technology |
Video Interfaces |
HDMI, DisplayPort |
HDCP Compatible |
Yes |
Max Monitors Supported |
3 |
Audio Output |
Sound Output Mode |
Stereo |
Max Sampling Rate |
192 kHz |
Compliant Standards |
High Definition Audio |
Speakers |
Bang & Olufsen sound bar |
Speakers Included |
2 x right / left channel |
Networking |
Ethernet Controller |
Intel I219-LM |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet |
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11i, IEEE 802.3az, IEEE 802.11x |
Expansion / Connectivity |
Bays |
1 (total) / 0 (free) x external 5.25" Slim Line , 1 internal 2.5" |
Slots |
1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 2 SO-DIMM 260-pin , 1 M.2 Card - 2280 (x4 mode) , 1 M.2 Card - 2280/2230 (x4 mode) |
Interfaces |
5 x USB 3.1 Gen 1 - Type A , 1 x DisplayPort , 1 x audio line-in/headphones/microphone , 1 x audio line-out/headphones , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x USB 3.1 Gen 1 - Type A (charging) , 1 x HDMI , 1 x USB-C 3.1 Gen 1 |
Miscellaneous |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington security slot |
VESA Mounting Interface |
100 x 100 mm |
ACPI, CCC, CECP, SEPA |
Power |
Device Type |
Power supply |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Factor Correction |
Yes (active) |
Operating System / Software |
OS Provided |
Windows 10 Pro 64-bit Edition English |
Software |
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager (free download), HP Velocity, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, HP JumpStart, HP Noise Cancellation, HP Notifications |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight |
Width |
53.96 cm |
Depth |
5.38 cm |
Height |
34.179 cm |
Weight |
6.13 kg |
Environmental Parameters |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
