HP 90W Smart AC Adapter
£41.78
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Connection versatility with a specially designed dongle allowing for simple conversion from the new standard 4.5mm connector to HP predecessor notebooks with 7.4mm connectors.
  • Operate with confidence with optimal performance using smart-pin technology and reduce the risk of power surges, while drawing only minimal power as needed.
  • Tight access made convenient – the new right-angled (90°) 4.5mm connector allows for connecting in limited spaces and reduces cord bending providing better cable management and longevity.
  • Device Type: Laptop
  • Stock Status: In Stock
Product codes
Provide optimal power and help offset power fluctuations to your HP notebook with a HP 90W Smart AC Adapter. Now available with a new right-angled (90°) connector that reduces cable stress and an optional 4.5mm to 7.4mm conversion dongle. As a replacement or back-up adapter, be prepared with the right connection.
Product Description HP Smart AC Adapter - power adapter - 90 Watt
Device Type Power adapter - external
Weight 370 g
Localisation English / United Kingdom
Output Voltage 19 V
Power Capacity 90 Watt
Included Accessories 4.5mm to 7.4mm power DC dongle
Dimensions (WxDxH) 12.7 cm x 5 cm x 2.9 cm
Designed For HP 34X G5; Chromebox G2; EliteBook 725 G4, 735 G5, 745 G4, 745 G5, 755 G4, 755 G5, 820 G4, 830 G5, 840 G4, 840 G5, 840r G4, 850 G4, 850 G5; EliteBook x360; ProBook 440 G4, 445 G6, 445r G6, 455 G6, 455r G6, 45X G4, 470 G4, 640 G5, 64X G3, 64X G4, 650 G4, 650 G5, 65X G3; Stream Pro 11 G4; ZBook 15u G4
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£41.78
