HP 973X High Yield Cyan Original PageWide Cartridge
£102.62
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Count on professional-quality results at high speeds, using Original HP PageWide cartridges.
  • Reduce costs for high-volume printing – high-yield cartridges deliver a lower cost per page than standard.
  • Spend less time troubleshooting device problems, using Original HP PageWide cartridges.
  • Stock Status: In Stock
Product codes
Count on professional-quality colour documents for a great value. Get a lower cost per page than standard cartridges and the results you expect every time with Original HP PageWide high-yield cartridges, precisely tuned to HP printers and MFPs.
Print 2.5x more pages at a lower cost per page than standard cartridges with Original HP PageWide high-yield cartridges. Get value your printer was built to deliver with high-volume printing for HP PageWide Pro 400 series devices.
Produce professional-quality colour documents at speeds your printer was built to achieve. Only Original HP PageWide cartridges are precisely engineered to match your HP printer’s high-speed performance, while producing professional-quality prints.
Get professional-quality pages and the performance you expect. Only Original HP PageWide cartridges are specially designed and precisely engineered for your HP printer or MFP – so you can count on fast, consistent results.
Easily replace cartridges in a snap, and tackle high-volume print jobs without interruptions. Original HP PageWide cartridges make printing easy, so you can make the most of your workday.
Product Description HP 973X - High Yield - cyan - original - PageWide - ink cartridge
Product Type Ink cartridge
Printing Technology Ink-jet
HP Sub-brand PageWide
Printing Colour Cyan (pigmented)
Cartridge Yield High Yield
Yield Up to 7000 pages
Compatible with PageWide Managed MFP P57750dw, P55250dw; PageWide Pro 452dn, 452dw, 452dwt, 477dn, 477dw, 477dwt
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP 973X High Yield Cya...
£102.62
