HP Active Pen - Digital pen - 2 buttons - for Elite x2 1012
£66.93
21 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Launch an app on your device from your pen with a programmable Bluetooth® feature that you can pair with your choice of frequently-used software.
  • Once in range, your device detects the pen and cues you where to place it onscreen. Erase, highlight, and click on your content with the two convenient side buttons.
  • Rest easy with a one-year limited warranty.
  • Use the pen to write or draw onscreen or interact with your touch applications. Integrated pressure sensors help you control the width of your drawn lines.
Product codes
Write naturally, launch an app with the touch of a button, and maximize your mobile productivity with the HP Active Pen with App Launch.
Launch an app on your tablet from your pen with a programmable Bluetooth® feature that you can pair with your choice of frequently-used software.
Once in range, your tablet1 detects the pen and cues you where to place it onscreen. Erase, highlight, and click on your content with the two convenient side buttons.
Compatible with the HP Elite x2 1012 G1.
HP Active Pen - digital pen
Digital pen
0.95 cm 14.729 cm
17.5 g
Buttons Qty
2
Pressure sensitive pen, application launcher
AAAA type
1 year warranty
Sprout Pro by HP G2; Elite x2 1012 G1, 1012 G2; EliteBook x360 1012 G2, 1020 G2, 1030 G2, 1030 G3; MX12 Retail Solution; Pro x2 612 G2
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Active Pen - Digita...
£66.93
