HP Adjustable Dual Monitor Stand
£177.74
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Accommodates notebooks that can be connected to a docking station and notebooks that do not have a docking connector.
  • Either or both displays can be rotated to landscape or portrait orientation.
  • Use two external displays up to 24 inches (60.9 cm) in size at once to increase productivity. Great for companies with Industrial Design, Order Tracking, Financial Analysis or Direct Marketing departments.
Product codes
HP Adjustable Dual Display Stand
The HP Adjustable Dual Display Stand allows you to use two displays to maximize your productivity and optimize efficiency. Either or both displays can be rotated to landscape or portrait orientation, and the stand is depth-, height- , tilt-, and angle-adjustable so you can view both screens at eye-level as well as slightly facing each other, letting you track multiple applications and information sources at the same time. Integrated base rollers let you rotate the stand so you can more easily share your work.
HP Adjustable Dual Display Stand - stand
Stand
Mounting Components
Stand base
50 cm x 35.5 cm x 40 cm
Adjustments
Tilt
5.6 kg
Recommended Use
2 LCD displays
Recommended Display Size
Up to 24"
Flat Panel Mount Interface
HP 245 G6, 250 G6, 25X G7; Chromebook 11 G6, 11A G6, 14 G5; Chromebook x360; EliteBook 1040 G4, 1050 G1, 735 G5, 745 G5, 820 G4, 830 G5, 840 G4, 840 G5, 840r G4, 850 G5; EliteBook x360; ProBook 430 G5, 430 G6, 440 G4, 440 G5, 440 G6, 450 G5, 45X G6, 640 G4, 645 G3, 650 G4; ProBook x360; Spectre x360
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Adjustable Dual Mon...
£177.74
