HP BA06 Long Life Battery (Secondary Battery Slice)
Key features
  • Be environmentally responsible and reduce overall battery waste by using fewer batteries over the life of the notebook.
  • Carry as a spare battery or eliminate the hassle of frequently looking for a place to charge up by using with your primary battery to boost battery life.
  • The slim, flat design doesn’t add bulk to the sleek notebook profile and fits easily into the carrying case with your laptop.
Product codes
The HP BA06 Long Life Battery is a slice battery that slides onto the bottom of the HP EliteBook Folio 9470m Notebook PC to help you be productive longer than using the primary battery alone.
Product Description HP BA06 - laptop battery - Li-Ion - 5400 mAh
Device Type Laptop battery
Weight 780 g
Battery Long life - Lithium Ion 6-cell - 5400 mAh
Batteries Qty 1
Dimensions (WxDxH) 32 cm x 21.3 cm x 0.7 cm
Manufacturer Warranty 1 year warranty
Designed For EliteBook Folio 9470m
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP BA06 Long Life Batt...
